I've just bought a 700 mm, 2000 model. It has been piped and has aftermarket reed valves and I have a strong suspicion that it has had the ports polished. The work was done when it was new by a reputable tuner. It has 1900 miles on it and wasn't used much for the last few years. The owner is a friend of mine and he treated the fuel and started it regularly while in storage. I checked the carbs and they are clean as new. I checked the main and pilot jets and they are fine. It ran fine when I first got it running and it suddenly began to foul plugs and not rev at all. It pops loudly in the exhaust on occasion. It now sounds like it is running on 2 cylinders and won't rev enough to kick in the clutch. The previous owner was very easy on it and it ran very strong when he put it away. It seems like the problem started suddenly. I have changed the gas. Could it be a fuel pump problem or something with the tors? I'm kind of stuck. I have never really driven the thing hard. Just up and down the drive in early snow. It seemed to work better for awhile when I changed the plugs and then it began to flood again. I have to watch the choke system so it completely releases but I can push it in now that I know that it is doing that. I have dried the plugs with a torch a couple of times. Is there a chance that they are not recovering from that? I can hardly see a spark when I pull it over with the plugs out. I'm stuck. Anyone have any ideas?
Thanks!
Thanks!
