yamahamark
What would make my carb leak by the drain plug. It's coming from the pointy piece beside the drain plug??
Thank for any info
Thank for any info
yamahamark
super1c
Super Moderator
Take the float bowl off and check inside. I had one crack and you could not really see it from outside and it was leaking. But the crack was seen from inside.
yamahamark
Is there away to fix it if it's cracked maybe JB weld? It's on my 95 vmax4.
Hammer Down
I've got many parts carbs for vmax4 if you need float bowls etc.
A couple of bucks
All I can picture is a big fireball w/ jb. At least on fuel related shtuff.
Cooper0809
A used float bowl shouldn't cost much. I would never JB weld...
yamahamark
Didn't think so on the JB weld I got that idea from a cat guy.
I'll pull the carbs off this weekend and see what's going on in there. I would have never noticed if my brother wasn't there being annoying like little brother's are. At first I thought he was joking again but this time he wasn't m. LOL
All I can picture is a big fireball w/ jb on fuel related shtuff.
It might not be the preferred method of repair, but it does work. 10 years ago, I broke one of the "posts" that holds the float assembly. I used a plastic straw as a form and poured a new post with JB weld. That bike is still running today.
yamahamark
How much for a carb bowl Hammer Down shipped to 49126?
Also I don't have PayPal but I could do a C.O.D money order.
caravanman
Thank for any info
That "pointy piece" is the nipple where you install the float adjusting sight tube.
The brass colored set screw next to it is the on/off valve if you will. It has a tapered end on it as a seal.
See if the tapered end on the screw is corroded, or the screw is just loose?
yamahamark
It was cracked and when I turned screw to take it out it broke the bowl.
super1c
Super Moderator
Sounds about the same as mine. Just get a new one!
caravanman
Bummer!
yamahamark
Going tomorrow to a local performance shop they think they have a couple of them lying around. Got some snow in the forecast and I want to be able to ride...
