Exciter 440 chain tension
jeffro9
ontaruio
79 ex440 what's the proper way to set the chain tension. I'm guessing remove cotter pin and loosen jam nut tighten by hand then back off a certain amount does any body know how much thanks
I turn back one half turn and put cotter pin back in. Don't want too loose
Does this pin look correct? or am I missing something here?? Because once I have the tension set and cotter pin installed, I don't see what is stoping the tension bolt from being able to loosen off .
