drew24
I am still thinking its clutch related but how about the exhaust? Is it partially plugged? Mice love to build nests in the exhaust.
ThatBlueVmax
What do the slider buttons look like and yes TORS disabled
Youllbe2nd
In your secondary clutch. Look at the helix ramp. The helix slides on three small black plastic looking things. These are the slider buttons. To replace them you'll need to disassemble the clutch and pop them out. Just be careful they break off in the hole easy. Replace with genuine Yamaha buttons because the cheap ones arent good for anything. They will crack and squish and break. Yamaha buttons are graphite or graphite impregnated or something like that and they are WAY BETTER.What do the slider buttons look like and yes TORS disabled
Sent from my E6560C using Tapatalk
A couple of bucks
Here's some help w/ disassembly.What do the slider buttons look like and yes TORS disabled
https://m.youtube.com/watch?v=5kdmUl8od-0
ThatBlueVmax
Thanks everyone for the help the crank seal is needing replaced.
ThatBlueVmax
Crank seal was replaced, didnt change anything took fuel pump apart there was a piece of foam and water in pump.
new filter in tank?
