abranz
Hello, I'm new here and just purchased a 01 700mm. It's stock other than the previous owner jetting the carbs with 140 pto, 138's on the middle and mag side. 55 pilots with their screws 1 5/8 out.
Is this correct jetting for 3000-5000ft? It runs well but sputters and seems rich during 1/3 throttle or less. It has stock exhaust. Thanks, Anthony.
Straight out of the book, but you didnt mention the needle setting. That could be your sputter. Yamaha says position #2 for the clip. Yamaha does error on he side of rich and if you have tuning parts on hand you could actually go a bit smaller on the mains, I did before pipes.
abranz
Is that position #2 from top or bottom of the needle? Thank you, appreciate the help
From the top. You also need to be correct on the shim orientation. If you cruise through the tech section you should find info as to setting the needle.
