krisdecker
To my understanding, the Aaen and Bender pipes (identical), came with both a center dump (stock outlet) and rear outlet as you have there...
krisdecker
Oh ok so This may in fact be OK to run with my other 93 Phazer II. However my 93 Phazer is absolutely mint and stock. Not sure I want to go hacking holes in it just yet.
yamahamark
It's an aaen for a phazer would make a couple hp but if your 93 is mint I wouldn't mess with it.
krisdecker
Thanks guys! Why would AAEN make two different exit points? Is the rear exit pipe better for flow than the center dump?
yamahamark
Different pipes for different applications but more of owner preference.
Throttle Junkie35
It could be an Exciter 570 pipe. Thats what it looks like to me.
Looks alot like on i had on my old exiter
BornYamaha
My original psi pipe on my 1st Phazer in the "80"s was rear dump so I had to cut a new hole. When I got my second Phazer in "90", psi had pipes available that exited the stock exhaust hole so I bought a new one rather than cut a hole in my brand new sled. Just progress over a few years. I would imagine that it was the the same way over at aaen. Just progress.
Sent from my SM-G920V using Tapatalk
BornYamaha
krisdecker
Now that you mention it. This pipe does look alot like my old Exciter did... Theres no way the phazer and exciter were interchangeable right?
Throttle Junkie35
No, they wouldnt interchange. If that pipe fits under the fan scoop on your phazer, then it would be a Phazer pipe..If it doesnt then my strong guess it that its an Exciter pipe.
Yamaha Nutz
aaen actually built 3 phazer pipes .......... quiet can, which exited the stock hole ....torquer pipe and race pipe both need new exit holes cut .....the race pipe has a straight silencer while the torquer has a flared one like you have pictured .....but the EX 570 pipe looked just like the torquer too
Yamaha Nutz
krisdecker
If anyone is interested Im going to sell this pipe. make me an offer! I purchased a DG center dump... which I noticed does alow some exhaust smoke into the engine hull. That cant be good. looks like the flange is slightly different that the stock pipe. is this normal?
any suggestions?
any suggestions?
Throttle Junkie35
Yep, its normal.
vmax-540
Could also be a 440 Exciter pipe.
