A couple of bucks
I'm your guy.
I'm watching a 36" printer as I type. If you want to send it to me and I can make some copies for you. I will need to tape the edges that are ripped so it will go through the scanner though.
A couple of bucks
That sounds like a plan!! Is it yours or will it be a "government project". Im looking to have some copies made and send them to Mr. Sled to use for prizes.
I'll send it just the way it is. I know some tape kinda reflects.
That's really cool. I wouldn't mind buying a copy if they aren't crazy expensive.
sleddineinar
I would offer, but if you need it scanned we don't have scanners in the building anymore.
I sent you a PM...
We might want to look into lamination too. Hmmmm.....
A couple of bucks
Yea. A slightly heavier lamination that you could lay it on your bench.
yamahamark
One of those would be great to have for a reference instead of wasting time on line searching.
sleddineinar
If you are going to scan that, I wouldn't mind and electronic version that I can print out on my large format printer.
I want one for cool factor!!
A couple of bucks
You'd have to see if JD is setup to put it on a Zip drive or something.If you are going to scan that, I wouldn't mind and electronic version that I can print out on my large format printer.
A couple of bucks
I wonder if it can be put on a pdf or whatever, so anyone could print it off at home. Then tape the 8(probably) sheets together?
Its $12 each to have laminations done... That's here at the local digicopy.
