Hello,
Was wondering if anyone has ever had this issue before? My sled started running on one cylinder at idle only last year,once off idle the midrange and full throttle seems fine.
I clean my carbs every year and did it twice this year for this specific reason thinking the idle circuit was plugged. It has spark on both holes and i replaced the spark plugs as well. When the mag side plug wire is pulled it makes a very slight difference in idle speed but when the PTO side is pulled it dies right away. In the past I had a similar problem but the issue was one of the slides for the throttle came out of adjusment and that was causing weird issues with idle but i am positive thats not the problem now.
I did a search on this and the only one I found that was having similar issues was a VK540 fan and it turned out his sled had a bent ring! I think his compression was 105 psi in each hole,he said his crank seals were bad too.
I have not done a comp test yet but will do that shortly and post reults.
I am the second owner of this machine owned it since 99 had 1900 miles on it when i got it now it has 7000. At about 5000 miles I put new rings in it (hope I didn't muck anything up) and took 1 layer of the head gasket out. Compression test after work was done was about 145psi in each hole.
Any advice,ideas welcomed Thanks
