j33p1nfamily
Trying to get best bang for the buck when it to comes to better throttle response. Stock sled, Ideas?
yamahamark
Reed spacers or stopper notch and remove 1 or 2 layers from head gasket.
sleddineinar
It also helps a lot to change the top gear in the chaincase, stock is 23 tooth. Use a 22 or even a 21, then also make sure the clutches are tuned properly. These things are not properly clutched from the factory.
A couple of bucks
Ditches, trails, groom or not, big open spaces, lakes etc. etc.. What's your riding habits.
roudyroy1
drill the can,jet it especially the needle jet. these sleds are fat
j33p1nfamily
Thanks for all the info guys
will update on what i have done.
will update on what i have done.j33p1nfamily
Mostly trails that are goat paths.. I do ride lakes but tend to ride the shore line with ice heaves to jumps.
j33p1nfamily
whats the stopper notch? I have heard of it but not sure what exactly what it is.
roudyroy1
it involves notching the reed stoppers to allow straighter flow into the boost port, this clears up the low speed hesitation. im not a fan of the reed notch due to the fact that you are weakening a part thats already known to break. i also feel that reed spacers are more effective since they get the whole stopper out of the way and are safer.
j33p1nfamily
So reed spacers are in and i installed a nicer set of carburetors. I used a set from an srx and switched out the jets. It runs but not right. One thing i remembered after was air jets. I never switched them or adjusted them to spec. It kind of starts like an srx. Choke it, it idles way up and wants to stall out until you choke it again. once your driving it will stall as soon as you stop and don't work the throttle. Could Air jets be my running problem? Along with idle adjustment?
What about needle jets, are they the same? I assume you used your pilot jet.?
chris700readhead
The needle jet on the pto side is bigger I believe on the wrx cabs and the pilots.
brianbailey440
best setup i had with stock 00 sxr 700 was what mr viper told me to do.reed spacers,142.5 mains in all three cylinders,needles in #3 position with both washers on top.bored the stock can,and changed the helix to an 8bvfa 51/43.put the stock carbs back on with this setup, and give that a try.i wouldnt mess with the head gasket personally.if you want it to hook hard, then remove the top spacers in the transfer rods, and adjust the springs on the rear shocks, and or full rate adjuster until the spaces are equal on the transfer rods top and bottom.it will ride smoother in the bumps, and hook 10 times better than stock.the front shock in the rear skid is what takes the big bumps,and the rear is your comfort.hope this helps.
j33p1nfamily
Wow thanks for all the info.. Will try all of this.
Sent from my SCH-I545 using Tapatalk
brianbailey440
let us know how it works
