Annihilator
Hi all, at the end of last season, I summerized my stock, great runnning SRX by fogging, cleaning, lubing, toping off fluids, etc.
My friend goes to get it running this year and is unable. He took apart the carbs and noticed they were full of oil.
I've had it a few years and never had problems or have heard of this before. Sled is stock and motor original with 4k miles.
Any ideas? I believe majority of the oil was Mystik full synthetic. Maybe too thin? Maybe oil pump?
roudyroy1
It's the check valve in the oil line. I went through this myself on my sxr. Although the valve stops oil flow in the wrong direction, the spring pressure on the ball valve stops gravity feeding.... Which is what your experiencing. I proved this: with my new valve I could not blow air through it in the direction of flow with my mouth. With the old valve I could with no effort as it was no longer sealing.
Annihilator
Ah I see... I see two check valves on the diagrahm partzillas site. Do you remember which one it was? Thanks again!
j33p1nfamily
I just ran into very similar problem. My brothers 02 viper would start when you put gas in the cylinders then stall right out. I pulled the fuel lines off the carburetors and pulled it over, nothing came out of the lines. Pulled fuel line off the tank that feeds the pump and it had oil in it, i blew though it and oil came out of the fuel lines to the carbs. Never saw this before. Think this is the same problem?? Ball valve in oil line?
j33p1nfamily
Guess I'll just order ball valve and hope for the best. Good luck on yours Annihilator.
Make sure they are installed the proper direction guys. Check then double check.
j33p1nfamily
I have two in parts diagram, should I replace both?
perfect diagnosis. nice job!!
roudyroy1
It was the one closest to the fuel pump
roudyroy1
Mine was the one closest to the fuel pump
j33p1nfamily
Great thanks for the help
Sent from my SCH-I545 using Tapatalk
Annihilator
Thank you much!
roudyroy1
Don't forget to mix oil in the gas for the first start as there will be an air pocket in the line.
And bleed it.
don't need to mix oil in the gas, just simply bleed the oilpump with the bleeder located right by the center cylinder on reed cage.
roudyroy1
If you are only changing that check valve by the pump you can get away with some premix for the first start, if any other lines are taken off then you must bleed it. Either route will work. In this situation
j33p1nfamily
Update.. Sleds back together and running great. Thanks again
