Kodman
I have a 2001 yamaha mountain max 700 and I have done a Tom of stuff to it, it has a new exhaust gaskets, a new ignition system, new lowered gears on the chain case, cleaned the carbs, new fuel filter, and rebuilt the primary clutch, and I dropped my main jets to 142.5, and my low to mid is absolutely fenominal, but once I get to 3/4 throttle to wot it starts to bog out on me, anyone experienced this or know what's going on? Can you adjust the timing on these sleds?
A couple of bucks
Have you powder and steam proofed it?
http://www.totallyamaha.net/threads/99487-97-Vmax-Powder-proof?highlight=Infamous
Does the problem go away if you flip it to 1/2 choke while up in that problem area?
Kodman
The choke only makes the issue worse, and yes it's been sno proofed. Any more ideas?
A couple of bucks
Well now we know there's enough fuel up in the problem RPMs. Let me think.
You may be leaning out at wot or your clutching is overshifting the power curve of the engine. Different needle setting, bigger main jets, or play with the secondary pre-load or helix.
A couple of bucks
I have a 45* helix for the cost of shipping($6) if you'd like. I also have a 41* but that's not going the right way for a fix.
Is your red Spring OE or new?
Have you preformed a plug chop up where it's wallowing?
My 01 MM really liked the 43 helix if your running at any altitude. I run multi angles on all my sleds now and off the top of my head I think that sled has a 49/42. It does have bender triples on it though.
A couple of bucks
Kodman,You may be leaning out at wot.
Snowdads comment got me thinking. When you flipped it to 1/2 choke, was the change instant(I'm thinking lack of O2),or did it take a few seconds(thinking excess fuel).
