j nicolazzo
can I run a 1.220'' lug on a stock 2001 Yamaha sxr 500 without any problems? thanks!
drew24
You should be fine as long as you are not running studs. Probably have to trim the track over the windows otherwise it will hit the tunnel protectors. I had to trim the track on my srx with a 1" track.
sgauthier
yap as drew24 mentioned you will be good. i'm running an 1.25" on a vmax 700 with a little trimming where the protectors are so the 1.22 should be good. put it on and spin it by hand and check for any issues.
1.25" fits no problem.
j nicolazzo
thanks for the help guys!
