1.220' lugs
You should be fine as long as you are not running studs. Probably have to trim the track over the windows otherwise it will hit the tunnel protectors. I had to trim the track on my srx with a 1" track.
yap as drew24 mentioned you will be good. i'm running an 1.25" on a vmax 700 with a little trimming where the protectors are so the 1.22 should be good. put it on and spin it by hand and check for any issues.
