brianbailey440
trying to better understand what rate, and force actually do when changing primary springs.i know that going to a heavier spring will increase rpm,and lower will decrease rpm.what i need to know is does a higher rate mean a slower shift?does a higher total force also mean a slower shift?example,i try a ywy primary spring with a 2.5 rate/128 total force.it works good, but my rpm is low on top,so i go to a ggg with a 2.75 rate/131 total force.i gain back some rpm, but it shifts totally different.the ywy gets me to 105 on the dreamometer, but the ggg gets me to 100, and the belt starts to slip on the top end.the ywy pulls better at the top, and the ggg pulls better at the bottom.the secondary is a green spring.why does the ggg work better on the bottom than the ywy, and vise versa?
