Victory!
Went out for a ride this morning. It was snowing alot. Trails were nice, good -12c weather. Sled ran 90% perfect with only a slight miss at 6500 rpms once in a while. I was so happy to be enjoying my sled again.
what were the temps when you were riding? maybe jetted rich for conditions.
This was probably 1/2 of the problem.
Turned out my problem was combination of things working against me.
-Two spark plug caps were on the verge of failure.
- Flywheel was very rusty. Don't know how much that effected things.
- My air filter screen on my air box had completly deteriated and wasn't sealing right. Causing at time snow ingestion. When i replaced with new foam and sealing strips it seemed to have richen the engine more
-Resetting my carb needles to factory specs. Worked great in the cold -20c weather but made the sled barely drivable when the weather warmed up.
T'ill two days ago started dropping down the needle on #1 carb a bit as it had the darkest plug. That helped. Even though the other two plugs were light in color I tried leaning them a 1/2 notch too. Things improved dramatically! I've been driving , checking plugs, and making small changes. Little by little throttle response improved. What a learning experience. Hoping the mystery is solved
Thanks for all the help guys.
