A couple of bucks
Hummmmm ...... Mabey I'm to be between Norwegians 500 recipe and Max's 700.
What kind of a set up are you looking for? Trail? Race?
Engagement rpm?
The MM 700 uses a different belt than the Vt 500, I assume you use the 89 L belt?
Engagement rpm?
Backwoods M Max
Engagement rpm?
I forgot to mention that too. I'm running an ultimax xs805 belt. If I had an 8dn on it you could probably add 500 rpm right there.
Backwood, if you're interrested, I have a good HC set up for you, with no let downs.
A couple of bucks
I'm running an Ultimax 4432U4 and looking for a trail set-up. And an engagement of @38/3900ish.
Try about 4 grams in the heel, 4,3 grams in the middle and the rest like my set up.
Backwoods M Max
Thanks,
I need to ride this setup more before I come to any conclusions. Peak rpm is right, engagement is coming down but I haven't ridden it enough to get the feel of the curve ( does it want to trench or not)
A couple of bucks
Both of you guys are running a straight 43*. What do ya think about a 43/37?
Sure, if you add some weight to the tip, it will more than likely work, with a higher top speed to boot.
You will likely also get better mpg than stock, because you can add up to 6 grams of weight in the middle hole, 8 if you use a nut on the other side.
A couple of bucks
Boomer had one FS in the classifieds. Just sent off for it. I'm thinkin I can dial her in w/ you guys help.
Be sure also to get a white spring to be able to have that low of an engagement, and a spring that is suited for your sled (the white)
A couple of bucks
For secondary springs I have a fresh green and a used red. I know Bender sells H/C stuff. Who else does?
All I have is a red & gray hc primary.
You need a white HC spring for your primary. For the secondary, a red or a green will do. Rich sells HC stuff.
Backwoods M Max
I have never been able to get bender on the phone when I try calling. I want to buy a billet primary clutch cover and wanted to know about balance but nobody ever answers the phone.
I bought mine from h/c direct.
i have gotten heel clicker stuff out of ulmer racing and i think hartman might sell it too.
Just an update on the heelclickers on my 97 VT 500:
Changed middle to 5,1 grams, up from 3,3 grams, and now it runs like a true 500 liquid. Now, with the increased speed, the front shocks can't cope.
Also, even with the too light 3,3 grams in the middle, I still managed 9,55 MPG, when riding with my girlfriend 2 up. One of the reasons this machine is so bad on fuel is that it runs at a high rpm almost all the time, compared to the speed it is going.
For a XT 600, try 6 grams in the middle (watch for spider clearance).
A couple of bucks
Is it common for there to be clearance issues. What needs to be done to insure that there won't be an issue.For a XT 600, try 6 grams in the middle (watch for spider clearance).
Sometimes it can be, just try moving the weight to the extreme left and the extreme right, and see if the bolt still clears the spider pocket, check this the whole of the range the weight moves.
Did you abandon the HC project A couple of bucks?
Update: I am going to lighten the heel from 5,2 grams to maybe 4 or even 3,5 to get the engagement to about 4000-4200. When engaging at 3600 the sled feels like it's in high gear all the time.
A couple of bucks
I'm just waiting for my tall cover from Viperking. It's too friggin hot in the garage. It's depressing.
