Putting together parts for a srx 780. Need help finding a ski doo head gasket.
drew24
NW Indiana
I need the inner o ring head gasket from a ski doo 9500 for my 780. I have found gasket kits for them but I would have to buy 2 kits just to get three o rings. Anyone know where I could find them individually. All the doo parts websites only go back to 1996. I haven't called a dealership yet.
drew, are you using a special head ? my 780 uses stk o-rings. 3:16x (yammie tony)
I talked to aaen and he told me they welded the o ring groove and machined it so it wasn't as close to the edge. I measured it and it was a little bigger than stock. A stock o ring will not fit. It is slightly too small.
Ok. Thanks guys. Not sure which way I am going to go yet. Might just buy the gasket kits if I can't find them individually. Better safe than sorry. It would cost a lot more than the 2 gasket kits to have a cylinder made if something happened. I have a stock oring over something a little bigger now to see if I can get it to stretch just a bit. Doesn't need much as it is close right now.
might want to try some of the industrial engine re-builders as they might have one that works for a desil liner if it does not work.
I ordered the ski doo top end gasket kit. I just got one kit for now till I confirm it is the right o ring.
stk o rings fit like a glove on my 780. don,t know. i guess it all depends on kit. 3:16x (yammie tony)
Yes, aaen told me that is how I would be able to confirm it was his kit so I think he is the only one that did that. Not a big deal. Just glad I caught it before I put it together.
Ski-doo part # 420831792 is the right o-ring for the head gasket on the aaen 780 srx kit. Just in case anyone ever has the same kit and needs the head gaskets maybe they will find this.
