I'm interested in buying this 2004 SX Venom with 6,400 miles on it. It has a new track that is studded down the middle. Electric start and reverse. No tears in the seat. The bad, it has a couple pinholes in the silencer, the other pipe is out of a wrecked sled and has a dent in it. The exhaust was spray can painted to hide the rust and looks like crap. I also noticed the carb boots are wrapped with electrical tape. The left ski is damaged on the outer edge pretty ugly but not sure if it needs to be replaced. Now the story, he bought it less than a year ago for $1800 and he will sell it to me for no less than $1200. What should I worry about here???
shaggyzr2
That sounds like a good deal at $1200, just make sure you replace those taped up carb boots.
A couple of bucks
I'd get it but know that work would be needed. Prioritize its needs.
I'm going to roll the dice on it i guess. Im not afraid to repair it, I just dont want to buy some amatures problem. The spray painted exhaust and electrical tape on the carb boots made me raise an eyebrow. I just don't do things that way personally. I dont know who put the track on or if it is even the right track for the machine. Things like this make me loose sleep at night.
A couple of bucks
Those boots might be just fine. Could be a AFU gasket.
Now explain the "afu" gasket again. My imagination leades me to believe you meant the "all f$@&*! up" gasket. How long do the crank seals usually last in these things?
shaggyzr2
The crank seals last a very long time. I've heard of guys getting well over 20,000 miles out of these engines.
A couple of bucks
You got it. If the tape is just wrapped around the cylinder/reed/carb boot mating surface, it's probably a gasket. If it's just on the rubber portion, then you'll need to replace with genuine Mikuni/oem parts. NEVER EVER EVER NEVER get an aftermarket carb boot. They are sh!t and will help you burn the sled down sooner-than-later.you meant the "all f$@&*! up" gasket.
Thats good to know! I'll see what I can post for pictures once I get it home. Maybe it is the "AFU Gasket". I haven't seen beneath the tape but i'm sure they don't call it that for no reason. I've been thinking about buying it for almost a month. He finally decided to take my offer!
http://www.totallyamaha.net/forums/threads/102175-Should-I-Buy-This-Sled
sleddineinar
Nice find!
