When doing this maintenance you also need to check the end of the power valve that the cable end or barrel slides into. They have a tendancy to spread open at the end and the cable can pull thru. Also when cleaning the valves make sure you clean the carbon build up behind the valve that may prevent it from opening fully. After you have cleaned and inspected them you will need to adjust all three cables at the servo motor end. Your old cables should be fine but will need this adjustment.
