Yamaha Nutz
more pics toward the end of the week ............. should have it in a roller as i am just finishing up building the skid
Yamaha Nutz
Yamaha Nutz
Throttle Junkie35
Very nice Mr. V,
Yamaha Nutz
Yamaha Nutz
Nice work! Knowing your skills, I am sure you squared that skid up prior to bolting it all together.
I couldnt tell from the pics, but the skid/tunnel cover did you leave it so it can be removed? Almost appeared as though you permenently attached it? I always kept mine separate for easier maintenance.
Now you just need a rear bumper. I always used 1.5" x 3/16 or 1/4 flat stock aluminum bent with the inside radius reinforced with a weld. Some countersunk allen heads with whizlock nuts on the back side makes a clean finish. I may even have some leftovers that fit that tunnel, if I can find them. Just need a tunnel width for fitment.
Yamaha Nutz
Yes the skid was squared up perfect during the test fitting and final adjustments made for a perfect fit in the chassis the finishing of the skid was the rear wheels and adding a few more wheel kits
oh ya i did get the rear bumper installed too ....lol i used a GPX rear bumper .....
tunnel extension/enclosure is permanently mounted even if i have to get to something on the skid there is plenty of room or if i pull the 2 rear arm bolts the skid drops out real easy so not much of a concern ......the way the skid is designed, if i have to make a major adjustment the whole thing has to come out and half apart anyway but for the most part as long as it is square there should be very little adjustments aside from ski pressure or rear spring pressure
Yamaha Nutz
not much to report lately tunnel is in polishing process and bulkhead will head out for blasting and then paint or powder coat ..i have not decided yet
then on to polishing the skid and belly pan then final assembly
A couple of bucks
If the hood is staying black, a black silver vein powder would look nice.then paint or powder coat ..i have not decided yet
Plus the silver vein hides imperfections in the metal.
Yamaha Nutz
I was going to do a retro paint sceme yellow with the black/white checker ...but since i am so far behind on the build and want to have it on the ice yet this winter it will get the best black panels i have until i have time to paint it .....it may just stay all black too
Throttle Junkie35
The only imperfections on Mike's sleds is the driver... LOLIf the hood is staying black, a black silver vein powder would look nice.
Yamaha Nutz
Hey now that is not nice to talk about my drivers like that ..............
Throttle Junkie35
opsled
TJ's just jealous that you hired his sister to drive your sleds.
Faster, better lookin and wears a bra big enough to hold his beer belly.
Understandable..
opschmuck
A couple of bucks
Nothing beats a War of the Cheeseheads.
Throttle Junkie35
Big LOL's
A couple of bucks
But seriously, how big is this over the shoulder boulder holder.
Throttle Junkie35
Sorry guys, I only have a brother...no sisters and he's straight....but I could put in a good word for you guys...you never know these days. LOLBut seriously, how big is this over the shoulder boulder holder.
A couple of bucks
Left turn Clyde.
