Master_o_69
Hi I recently purchased an 01 Yamaha srx 700 and had a couple of questions about it so decided to join this forum. The sled runs great but the only thing wrong with it is the temp light flashes a code, the flas pattern is a total of three flashes with 2 long flashes and one short one all within 3 - 4 seconds I looked up the chart and believe it is either a bad temp sensor or a bad tps sensor but I'm not sure which as I have always ridden articcat's and don't know much about Yamahas also if it is a bad tps or temp sensor would it be ok to ride it like that or should I get someone to fix it, also it idles pretty high at about 1500 rpm I was told it should idle at 900 but I backed the idle screw all the way out and it dropped to about 1200 rpm any input would help
Thanks, Antonio
Thanks, Antonio
