MarcB
Hi All, I have been away from snowmobiling since 1999 and I have missed the sport ever since. So I decided to pick up where I left off and just purchased a 1999 Vmax 700 with 5500 kilometres on it and looks in amaizing shape. I am looking forward to working on it to get it ready for next season. The previous owner said the only two things wrong with the machine is the broken trip reset button and that the tach stops working sporadically. If any of you knowledgable owners can give me some direction on repairing these two issues and any others things to look for would be greatly appreciated. Thanks MarcB
Vincent
Well-known member
Congrats on you purchase, and your reintroduction to the sport. Any pix?
MarcB
MarcB
Vincent
Well-known member
Very nice. Did you get a chance to ride it?
MarcB
No I just bought it and now going thru everything.
Vincent
Well-known member
Tachometer is most likely a loose wire. Don't know if you have electric start, but on my Venture 700 if I disconnect the battery I lose the tach.
MarcB
I see there is a valve on/off on the top of engine by air intake it seems ceased can you tell me what this valve is for? Thanks
shaggyzr2
The valve is for the heated carbs.
MarcB
Yes I figured it out, it seems ceased but I don't think they are used much around here right. Do you use yours?
MarcB
Nice looking sleds Shaggys
shaggyzr2
Vincent
Well-known member
In what shape is the track? Is it stock & original, aftermarket, studed?
ClayNation
Hi -
My friend has a similar problem on the exact same sled you have. Did you figure out the issue with your tach? The battery in his sled is dead, so we are wondering if that is the issue.
Thank you.
Thank you.
It's probably the battery, I have had a few electric start vmax's and the tach's don't like to work right with dead batteries?
ClayNation
Great - thank you!
