I purchase a srx for real cheap because it had no compression in 1 cylinder and low compression in the others. Started to tear the motor down and discovered the cylinder with no compression had already been rebuild with a weisco piston. So I figured bad crank seal, I completely disassembled the motor and replaced the seals and the crank was already welded, reassemble the motor and went to clean the carbs and notice that all the carbs had the same jets in them and the same pilot jets as well, it has 155.3 mains and 45 pilot jets. I need help as why someone would do that? I also noticed the baffle was out of the air box too. It has the stock pipes on it yet. Any help would be appreciated thanks.
