even adding 1 extra base gasket is only gonna raise it another .010-.011", your center reading of .027" would still be too tight at .037-.038". The bad about stacking up base gaskets is you will gain deck clearance and you cant get rid of that, it might make the squish clearance better but you lose the ability for the head to work properly because you moved the whole cylinder up, then your piston at BDC can end up not in time with the transfer port openings and main exhaust.
I would recheck it again with thicker solder, I use .060-.080". if it comes out to the same reading, the only way to correctly fix that is to have the heads rechambered, and the center one would need to be set up for that cylinder if its that much different again on the reading.
did you pay attention to the deck clearance when you put it together? the pistons should of just barely sat down in the cylinder on the edge, about .010", if they are flush or above then the cylinders have been machined on the bottoms.
