Well my sled seriously rips with this new ported engine! Very responsive and fun to ride.im over revving a bit 8700-8800 rpms I'd say. I like the low engagement with the www spring and the way it feels! Need to figure how much weight to add, currently running 8dn 10's with 3.6 gram rivets
Sent from my SAMSUNG-SM-J120A using Tapatalk
put 4.5 gram rivets in the tips, and check rpm with everything else the same. You can always grind a tad off the big head side of the rivets if 4.0 grams gets you spot on at 8500rpm..
SWEDE
Ok, thanks for the advice!
SWEDE
I added 1 gram to the tip of my weights and it goes right to 8500-8600 rpms and creeps up a touch more on a long run. It does feel stronger this way. I misspoke, I already had 4.5 grams outer hole so I added a new rivet with a 1 gram washer under the head. 3.6 gram in the inner hole for sure.
