Its 12v. You can also lower the idle to about 900 rpms with the servo cover off and watch the servo wheel open the valves. When they open shut it down. You can get it to do it just by choking it to get the rpms down till it opens
I believe that I don't need to run the sled 01 SRX as per manual ...it only indicates key on with power supplied at harness. Is that correct?
