merc9193
I have 3 screws on 2 PV's that the allen is stripped. Any tricks to getting these out? not sure if the previous owner or Yamaha put thread lock on them. The PV I got out was very carboned up not sure they have ever been cleaned in 4500 miles. The other ones were very had to beak loose and had a white powder on the bolt. should I put anti-seize on the screws?
drew24
Sometimes you can get a standard allen forced in when they are stripped. The impact drivers you hit with a hammer would work well if you could get a little bigger allen in it. They probably have corrosion from the aluminum on them.
YAMMIEGOD3:16
alright i am gonna get stupid. but just maybe. get a dremel with a small cut stone. see if you can cut a deep skinny slot enough to maybe a screw, than get a big screwdriver on them. another words, can ya make them a screw. just a shot. 3:16x (yammie tony)
staggs65
You can try an easy out that just barely fits in the socket. Worth a shot if you have a set
hessracing
i had this happen to the one on the bottom on the pipe side i took my pipes off and got a needle nose vise grips and was lucky and got it out!!
roudyroy1
vise grips, if not slot the head with a hacksaw blade or dermal and take an impact drive (not gun) if you have one.
I would try the slot method. Get some penetrating oil in there also and consider a little heat. A "little" heat.
Not sure why I'm giving advice. Right now, I'm locked out of my snowmobile trailer due to two locks that aren't cooperating. It just seems wrong....
a nice sharp cold chisel, lay it back at a good angle and quickly strike the edge of the head of the bolt it will jolt it loose and you can get them out.(Dont need a big hammer just a quick strike and the chisel needs to be laid back , your not trying to cut it off just spin the bolt head in the loose direction.) they get tight from putting steel against aluminum overtime it creates a galvanic bond. Put new bolts in and spray with some good antiseize or good oil like kroil also works well.
merc9193
Great Ideas, of course 2 are on the bottom hard to reach. I should get the replacements on Tuesday. So I will try those tricks. I cleaned the one and put it back together supposed to get snow this weekend. so I can finally try them out after I've been doing all the maintinence
shaggyzr2
vise grip
Master_o_69
try lightly tapping the next size up allen into it and see if it will grab if not its time to bust out the needle nose vise grips
