SRV clutch?
northern srx
Lifetime VIP Member
georgetown ontario
I have a clutch from a 1988 Exciter and was wondering if it would fit on the SRV crank properly? Anyone know if the taper and length would be correct? Obviously need to calibrate it properly for the motor. Thanks.
NO IT WONT!!!! The fixed sheave on Phazers and SRV's are machined to fit inside the oil pump gear case. The Exciter is not machined. You can ,however spin your old srv sheave on to the exciter clutch..or you can turn down the boss on the back of the exciter sheave.
