I have a clutch from a 1988 Exciter and was wondering if it would fit on the SRV crank properly? Anyone know if the taper and length would be correct? Obviously need to calibrate it properly for the motor. Thanks.
Yamaha Nutz
yes it should fit just fine and i bet the clutching may work nice for the 540 too
Thank you for the quick response! I'll try it out.
Throttle Junkie35
NO IT WONT!!!! The fixed sheave on Phazers and SRV's are machined to fit inside the oil pump gear case. The Exciter is not machined. You can ,however spin your old srv sheave on to the exciter clutch..or you can turn down the boss on the back of the exciter sheave.
