Clutch rivet substitute
LePere433
Northern Ontario
Wondering what you fellas are using as a replacement for drilling and pounding rivets out when you're tuning your clutch? Both OEM Yamaha weights and aftermarket?
I use nuts and bolts if needed. The biggest thing you need to watch is making sure your hardware clears the (clutch) spiders pocket inside and doesnt catch on the sides or it will get real ugly fast.
1/4"-28 hardware will work in oem weights if you carefully and slowly run a tap thru the stock hole. It will just barely cut threads allowing you to thread in the new bolts. use locktite on hardware.
10-32 button head bolts,, washers,, and jam nuts......... Bring your gram scale with you,,,, want them all the same.............
