oreo3156
that's how my foam was, worked like crap. take it out and put it on the top
switch it, jack it up and crank on it for now to test...
oreo3156
nick5oh
nice getting that ski on a srx. now thats cool. lol 3:16x (yammie tony)
p.s. and fix your air box will ya
NO NO NO! That ski is not on the SRX. Its a 4 banger beauty.....
And YES...I WILL fix my airbox for sure. Hopefully it works!
nick5oh
Switched to what? Invalid attachment ?
oreo3156
YAMMIEGOD3:16
i know thats a vmax 4 ski. show the rest of the sled. lol. and correct picture above. 3:16x (yammie tony)
brethren
Is it just the pictures or is that filter really dirty? Any chance you can try some varsol or detergent on it?
Sent from my SGH-I337M using Tapatalk
nick5oh
Thanks for the pics! Gotta change my foam. I love the difference in cable routing on that sled compared to my 99.
nick5oh
There's a buncha pics and a sweet video in the vmax 4 section here. Check it out you will love it buddy!
Also thanks for the clarification on the friggin foam! Can't believe that this may be my issue lol
nick5oh
Thought of something here.for shits n giggles.....were you getting no power top rpm on the trail or on a stand? My sled will rev up on a stand but not loaded on the trail?
drew24
All you need is a throttle cable for a 00-02 srx. I didn't like it either on my 99Thanks for the pics! Gotta change my foam. I love the difference in cable routing on that sled compared to my 99.
nick5oh
Kinda thought so....the oil pump cable would still be in the way of the airbox as well though. I guess that can be changed too.
drew24
The oil pump cable is long enough to go around the air box.Kinda thought so....the oil pump cable would still be in the way of the airbox as well though. I guess that can be changed too.
nick5oh
Good to know imma order a throttle cable I can't stand the cables being there
nick5oh
To the op can you confirm bog on trail only or on a stand?
hessracing
I do not run the foam on my 2000 SRX 700 it runs better with out it. When I have the cover on it i get the same bog you guys are experiencing. With out it it pulls like crazy!
Sounds like the carbs need more air. Pull plugs immediately after a wide open stint. To me the carbs get enough air when the box is off but then too restricted just trying to pull through an empty air box.
nick5oh
Doesn't appear that the cable is long enough to route nicely around the airbox. I may give it a go though to confirm.it appears it would be on a weird angle and have tension on it.
Got my pv's adjusted and cleaned, hopefully adjusted correctly. Riding this weekend so hopefully I have no rpm pulling issues. If I do I'm lost
Op never confirmed whether the issue pulling rpm was when riding loaded up or unloaded on a stand. I know my sled will rev up on a stand but riding it will not. My foam is in wrong. We shall see this weekend how it does
drew24
You might have to move cables and wiring around under the handlebars. Also make sure it doesn't pull apart when you turn the handlebars. Unless someone else put a different cable on mine before I got it. It is a different part number for the 00-02.
nick5oh
GUESS WHAT BOYS! Bog no more BIG jam on this bad boy!
