new member 2001 SRX 700 136 M-10
madmav3024
chelmsford ma
Time to rebuild the prim and 2nd clutches.not sure whats in it now i will look and post.what would be a good setup on this? ALL AROUND TRAILS AND LAKE?????Thanks
In my 136" I was running the stock 8dn-20 weights with 4.5 grams in the inner hole and 5.5 grams in the tip with a white-white-white primary spring and green dot secondary spring at 70 with a 51/45 helix and 23/40 gearing and rpms were perfect and it pulled pretty hard and had decent backshift. Do some searching on here. There are tons of setups. Also double check to make sure you have 9 tooth drivers as that makes a big difference in clutching.
