New to me SXR 600 Issue #1
There's a relay. They will act up. Sometimes, if you're lucky, the lights will come on after the sled warms up a couple minutes. There could be wires that have rubbed through also. My bet would be the relay though. Good luck.
Look for rub through on wire harness under engine. best way is to unhook at headlight harness connection. Tie a string on to it so you can pull back under engine. then pull harness out from under engine from under air box. Easier then it sounds and very common problem.
