blueorrfan
OK, as I unload the sled from the trailer I notice no lights....is their a fuse or anything?
			Weatherbyman
There's a relay. They will act up. Sometimes, if you're lucky, the lights will come on after the sled warms up a couple minutes. There could be wires that have rubbed through also. My bet would be the relay though. Good luck.
			blueorrfan
Thanks...printed off wiring diagram....look in a Cpl days when I have time.
		super1c
Super Moderator
Look for rub through on wire harness under engine.   best way is to unhook at headlight harness connection.   Tie a string on to it so you can pull back under engine.   then pull harness out from under engine from under air box.   Easier then it sounds and very common problem.
