00 SRX not starting... something electrical
2000ws6transam
northern michigan
Well first off, I took it for a ride a few weeks ago going 40 to 50 down trails and the lights all cut out for a couple seconds.... next thing I noticed was the light didn't come on one day when it was out getting warmed up for almost 2 minutes, then I did a edge swap in it , started it up and it ran for a minute and the headlight cut out then 10 seconds or so later the engine died. Now I checked the spark and its not getting any and wont start at all. First thing i checked was wiring connections they all seemed good and tight. tomorrow i was planning on checking the ground wires. Not sure where there are all located. under the engine , up front and ?? and any other advice? Maybe bad stator??? what to look for ? thanks for the help!
my 00 srx did that years ago when still new. harness rubbed on chassis right beside coolant hose. very com,on. you will find that. give your harness good look over. 3:16x (yammie tony)
