Motodeficient
Thanks I'll see if I can contact the seller to change the order
Motodeficient
The seller was able to change my order so I am getting the RSI chromoly steel bars and removable hooks.
I can't remember how I did this on my last sled- Should I apply the grip heaters directly to the steel bars, or wrap some electrical tape on the bars, then put the heaters on, or....?
Motodeficient
Nobody has put aftermarket grip heaters on aftermarket bars?
devinzz1
I used the rsi heaters. definitely not as good as the ridiculously hot factory ones but they worked. I didnt have them for long until i sold the whole bar setup (was to high but i regret not just getting a shorter riser). Heres super old pics.
Motodeficient
Did you put the heaters directly on the bars?
That is a pretty high setup!
I am putting on 7" risers with flat bars and a pivot adapter. Feels pretty good so far just mocked up.
devinzz1
I did this on my 02 Viper.
http://www.totallyamaha.net/forums/showthread.php/78800-Viper-with-Apex-Bars
Went with the 07+ Apex bars. I like the heated hook. Had to mod the throttle block to get it on but it worked perfectly.
YamiSwami
Here is a NOOB questions...
What is the benefit of using a bar riser? Does it pertain to ergo ?
Some like the higher bars even with stock seating height, but the real motivation for bar risers is off-trail riding where you stand up most of the time. These generations of sleds had such a low seating position and handlebar height that you had to bend over to ride standing up. Not very good for seeing and controlling the sled. Once you raise the bars about 6 - 8 inches you can ride standing straight up and have much better control for sidehilling etc. Of course then you need to raise the seat because you do need to ride the trail to get to the legal off-trail riding areas in most places.
My 02/03 Mtn Viper has the seat about even with the gas cap and the bars at arms length with elbows relaxed and slightly bent while standing straight up. Jump on a current mountain sled and you will get the idea. It makes it much easier to control and switch sides for opposite foot forward riding.
YamiSwami
I appreciate the reply Ding. I think I might add a small maybe 3 or 4 inch riser to mine were i can increase the height but not have to get new cables. I like the dressed down look of the bars its what they all look like now with hand guards. I guess with stock seat and small rise in the bars would make for better ergo and form when on the trails.
YamiSwami
reopening an old thread..
I would like to raise my bars without altering the cables etc. what is the max height I can achieve without swapping cables and where do you order the riser?
Motodeficient
Maybe 6" total
the easyest riser to put on any srx or viper is a 2" riser. i have put one on my fathers 2005 sx venture and it was snug to do but fit.
super1c
Super Moderator
3 1/2 rox pivot riser. Perfect for viper without cable change. Just have to run throttle cables under bar instead of over. I also liked a 1” block riser with rox 2” pivot rise. No cable change need with either.
https://roxspeedfx.com/collections/...ivoting-bar-risers-for-7-8-or-1-1-8-handlebar
blackhecilopters
I have the 3.5" and it's pretty tight. Any advice? I ran the cables under but also had to run them under the hood.
super1c
Super Moderator
What do u mean by under the hood?
blackhecilopters
Outside of the hole where all the cables go through normally, so they are sandwiched under the hood when its closed. I just can't get them run in a safe way...
super1c
Super Moderator
No that is not right. Not sure what u have going on but should be just fine running normal way.
