JohnnyG383
Hi in a bit of a bind and any help in how to remove the speedo insert in the drive shaft. I bought the sled with the speedo not working and last owner said he replaced the cluster due to it was frozen but the speedo key was also broken and I could not get the oil parts out of the insert on the drive shaft so I drilled it but need to get it to put the new part in and I screwed a self tapper in and been trying to pull on it with vice grips but it will not budge is there and method to this madness?
