yamahakid88
Hey guys, having trouble figuring out why one cylinder looks the way it does. The 2 other cylinders I know are running rich. All 3 carbs had the same jets and settings, so im not sure why this one looks leaner
http://imgur.com/a/iGe6t
its richer on the pto cylinder, not leaner. Its mostly due to that cylinder has a lower compression ratio then does the center and mag cylinders. Yamaha did this so you could use the same jet in all 3 cylinders. if you look at the head youll notice the pto cylinder has a larger dome, and if you put on a compression guage it will be lower in the pto.
yamahakid88
I thought the darker the piston the richer it is?
your pto piston pic is richer then the other 2 are, its more silver because the gas washes off the carbon. If it was all dry and silver with a sandblast appearance it would be leaner, but yours is richer.
yamahakid88
Ok so I would need to go on the center and mag side? It has triple pipes and it was running 165 mains with 45 pilots across. Needles at stock height and 2 turns out on the screws
Danger Dog
The mag and center are pretty lean for trail riding.
yamahakid88
I richened up the pilots on all 3, what do you think I should do to richen up the 2 cylinders that are lean?
HDYAMAHA84
what was the reasoning of pulling the head off?
yamahakid88
I bought the sled and I didnt think it had the opticool headgasket on it so I swapped it out
Danger Dog
I would richen the needles to start
yamahakid88
Ok, should I keep the main jets at 165 across then and adjust the needles?
A couple of bucks
Lower clip position as follows(towards the pointy end)
Center 1 clip position and mag 1.5
Vincent
Can you post pictures of the other two cylinders but from a better angle?
what brand pipes are you running on this viper?
yamahakid88
I really dont have any better pictures, I already closed it up. They are bender pipes. Will have to tear into the carbs again then. Can the needles be adjusted without taking the carbs out
Danger Dog
Yes they can.
just raise the needles a tad (1/2 spot)on the center and mag cylinder, look up needle adjustment on here theres even a thread or 2 with pics. if you have never done it before, I might suggest taking the carb rack off and doing them on a bench so you don't drop the screws and shims into the engine bay and invent new cuss words....
yamahakid88
Ok ill do that, you think the #1 cylinder looks ok then?
yamahakid88
Ok, raised the needles like you said, 1/5 turns out on fuel screws, 55 pilots and 165 mains. I did not touch the needle of the pto side piston, should that be ok?
ya you should be good to go, take it out for a good rip and kill it and look at plugs and piston top
