So I bought a 1997 Vmax 500 last year that was owned by a guy that used to ride it in the mountains. As far as I can tell and based on some old receipts I found he had some clutching mods done to run the higher elevations and accompany the 136"x1 3/4" track he put under it.
So I've brought this sled out east and I seem to have an issue with rpm's falling off now. It will rev up to about 7700rpm and then once you get up to speed the track speed drops a bit to around 70-80km/h and rpm's start to fall off down to about 6200-6500rpm. I don't believe it's an engine issue as it runs just fine, no bog or anything. I'm clutch illiterate though so not sure if it's a primary or secondary issue, weight issue, spring issue or what although I feel in the end my issue is going to be in the primary.
So to start with does anyone know what a 1997 vmax 500 would have in it for spring colour and weights in the primary? And any tips on how to diagnose which part of the clutch would be the best place to start making changes?
