So, had the motor drop a skirt on the exhaust side last weekend, and the other piston was cracked as well.
Understandable, as the cylinders are old, and out of normal wear spec at this point. Sending them away to get re-plated.
What I cant wrap my head around, is the reeds.
Right before winter, I installed a set of SRX reeds w/notch. They were perfect when I installed them.
Picture is after about 50 miles or less of riding.
Both sets of reeds had the damage on the bottom, but nothing on the top side.
My sled is as follows:
1997 XTC 600
Bender Porting
Single Layer head gasket
21 tooth top sprocket
Bender silencer w/stock pipe
Fairly stock clutching
1997 XTC 600
Bender Porting
