shaggyzr2
I have a 95 Phazer II, clutch engages at around 2500 rpm, looks like it should be at 3300. Shift rpm's are at around 6800. Belt is new, 89L-17641-01-00, both clutches are clean and in good shape. What would cause the engagement rpm to be low? could it be a worn primary spring? What color spring should be in there? thanks
Looking in my manual it calls for a green/yellow up to 2000 feet. and gold/pink 2000-6000. I think if the new belt is sitting to high in the 2ndary clutch could cause the sled to creep or engage a little early also???
shaggyzr2
The sled doesn't creep at all. I found the motor mount bolts on the clutch side are loose, I'm thinking that may be the problem, I'll tighten them up tomorrow and see what happens.
Yamaha Nutz
primary spring should be a gold/blue/gold
shaggyzr2
Right now it has a red blue red, how much of a difference is there between the gold blue gold and the red blue red?primary spring should be a gold/blue/gold
A couple of bucks
shaggyzr2
Thanks guys
