Mrcrowley
I have a feeling this will be aon going post till I get my carbs back together . Anyways on the float is the square spring on float valve supposed to go over the float adjustment tab or under? SOmeone said Pilot screw from being tightened 1 and 1/2 turns out but the manual say's 2 turns out which should I do? Do I have reed valves in my sled and should I replace them while I have carbs off? I have need float valves and seats and all new orings I did a enitail cleaning till I found out the Pilots needles orings on two carbs were disintegrated . Do I really need to replace the Orings in the Chock assembly ? And leveling the float if it is inline with to where the float bowl seats that is correct isnt it?
Thanks for any help you guys can offer .
( I would go so far as to ask for someone to do facetime with me to guild me along this is the first time I have had to do a carb on a larger machine like this so offer stands)
Sincerly JIm
(Psss...I am trying to get this old boy running for this weekend family is coming up and I would love to give granddaughter a ride on the tried and true machine .... )
Sincerly JIm
