MeanDean85
Hello new to the forum. Was working on my viper today and decided to check the gap for the oil pump. Never touched it before. It measured about 15 mm. I've had no problems with the sled. I was wondering what it was set to from the factory many years ago. No mods second owner. 2850 on the clock. Thank you
20.5 mm +-1
super1c
Super Moderator
Are you measuring gap with cable fully extended? Seems like 15 would be hard to achieve, not enough adjustment. And you would use a ton of oil at 15mm spec.
MeanDean85
All I have to do it pull the cable up from the boot rite? I'll check it again but I don't have much smoke when she's warmed up. It's never been adj don't want to mess it up.
