Martin Hall
I live in Maine and I need a track that can handle the drifts and hard pack. I also whant to run studs ? We have the mostly really loose snow or really sticky snow and we just got 3 feet of powder!! I don't care if I have loose top end speed.
Sounds like a 1,25 inch ripsaw will fit your riding style. If you buy one, be sure you buy the correct length, width and pitch.
A couple of bucks
Are you considering new tracks? If so a 1.6 Cobra is a good fit for a Maine winter. A 1.6 Ice Cobra if you must have studs. There are many members on here w/ Cobras who do not miss there studs at all w/ this track.
The Cobra is hard to beat for that.
Martin Hall
Well the thing is if I don't run studs , then the trails get hard I will have cooling problems I think ice scratchers would help ? I have the rear heat exchanger, but it still makes me nervous. Also going with opta cool head gasket when I rebuild the engine.
shaggyzr2
I ran all weekend with a non studded track on my srx, trails were very hard/icy not much snow being kicked up to cool it, didn't have any problems with it over heating.
Vincent
The 1.35" Cobra is fantastic for On / Off trail conditions!
Martin Hall
Well I never have had the temp light come on ,but I don't like to push my luck lol . I hear that sx vipers and venoms run hot anyway, so I m considering the optacool head gasket what do you think ? Yes or no ? I think I m going with a cobra 1.635 track because every one loves it so much.
Martin Hall
Can someone show me a optacool head gasket next to a stock one .?? I think I can modify the stock one to flow better I usual match all my gaskets to the transfer ports on all my sleds ,y can't I do it on the water jacket s in my head ? Right?
A couple of bucks
Start at #53.
http://www.totallyamaha.net/forums/...project!!/page3?highlight=Opticool+difference
Your not asking for your Venom are you?
super1c
Super Moderator
1.35 cobra for sure. I don't thing they make the 1.6 for a121. But I've been off my game a bit lately so worth a check.
Martin Hall
Yes I am
Martin Hall
Yea I am
Martin Hall
Start at #53.
Your not asking for your Venom are you?[/QUOTE
Yes i am asking for the venom 600 read head ]
A couple of bucks
They are for Vipers only.
A couple of bucks
They just make a 15x121x1.6x2.52 in an Ice Cobra.I don't thing they make the 1.6 for a121.
I saw the 1.6 Ice Cobra and figured they had a regular 1.6. My bust.
Martin Hall
Ok that's fine
Hammer Down
I ran the 1.22" ice ripper on my srx. It worked great and went thru deep powder. Won't a 1.6 track rub or do the vipers have more clearance? That 1.22 rubbed my protectors and I had to remove the front cooler protector.
A couple of bucks
You are correct. I should have added that in my previous.That 1.22 rubbed my protectors and I had to remove the front cooler protector.
