Yamaha Nutz
billybaru13
Nice work!
You won over modified 600 liquids with that sled? That's impressive!
Vincent
That is very impressive!
Yamaha Nutz
Thanks guys i must say this little phazer is powered by a far from stock phazer engine that i have spent many hours over the years improving on the port map to get it wear it is today and it is just a .020'' overbore as i do not like wiseco pistons in these engines our other phazer ran 77.8 mph which took 4th the sled i lost too was a very well set up triple piped SxR 600 that i believe ran 84.7 if i remember right .....all about power to weight ratios
shaggyzr2
Do you have any videos of it?
Yamaha Nutz
i do not but a buddy might ...
shaggyzr2
That would be cool to see it go
Throttle Junkie35
I saw this first hand. That sled goes!!! For reference, 3rd place went to a tripple piped 87 Indy 600 slammed to the ground picked and chiseled track. My 88 Exciter set up for trail with 96 worn out trail studs, Vmax 600 engine with exciter psi twins ran 77.6.
JGRIZZ
Cool Sled for sure !!
Took my oval racing phazer to some 600 ft speed runs this past weekend took home 2'nd in the 0-600 class
with its best pass of 79.6 mph, still a little left yet as I was over reving by 250 rpm
