kallio
I've been online and everything is showing the primary and secondary spring as not an option to purchase? does anyone on here carry stock springs for the Yamaha clutches?
YAMMIEGOD3:16
koch performance. 3:16x (yammie tony)
Yamaha Nutz
secondary Yellow, and silver depending on the year for the secondary have long been discontinued, same goes for just about all primary springs what year sled or what springs are you looking for
kallio
trying to find stock springs for a 79 ex440. two years ago I was able to trace down some of the last remaining inventory for the primary and secondary clutches from Yamaha dealers but it took a while.
kallio
i have an 80 and 79 ex440. i just picked upthe 79 two weeks ago and want to get it running with the 80....
kallio
I contacted Koch and they have nothing. in another post Yamaha nutz, I read that another years spring might work. how to do you know what the spring is and what might be comparable when all I can find online are part numbers.
the stock spring is a blue green.
also, how do you know if a spring is soft? what are the signs, will it get longer or shorter? I have the spring from my 80 primary when I changed it a couple years ago and it measures at 88.5 mm. I think I read somewhere the stock one is 86.5?
A couple of bucks
Yamaha Nutz
I don't know if this is old enough.
that spring chart is useless for the old springs
Yamaha Nutz
unless your secondary spring is a complete rusted mess it is probably just fine the blue green is a std phazer spring and used on the 79-80 ex 440's i never cared for that spring a 90-91 phazer yellow green spring will give it a little more engagement and nicer shift but once again a spring that is NLA ... i will look i may have a few nice ones yet
kallio
thank you
