FredrikMoström
Hey all Bender 835 fans! I recently got a set of bender 835 cylinders and a head for it but no pistons. I live in Sweden so it is quite a long wait for som pistons from Bender and they are a bit pricey. I have read all there is about Bender 835 on the web and have seen some people say that some sort of ski-doo piston may fit? So my question is if there are someone in here who knows which piston may fit exept Benders? The bore of my cylinders is about 76mm. Hope someone can help me. Best regards Fredrik
pete_man26
I have a spare sitting on my bench for the 835 SRX, I can get you measurements and take a picture for you if that helps?
FredrikMoström
That would be great!
FredrikMoström
How is it going Pete?
pete_man26
Sorry, I completely forgot! I put it in my phone calendar with an alarm to check tonight after work!
pete_man26
Diameter 2.966"
Height Skirt to edge of dome 2.521"
Wrist Pin Bore .787" (should be same as stock)
Top of wrist pin bore to edge of dome .825"
intake port to edge of dome .886"
Sorry for the imperial measurements, my caliper and micrometer didn't have the conversion built in.
