anynone got a idea what a srx with a ported cylinder ported case ,,35mm carb , bump compression with c12 gaz could do about hp on a dyno ....i plan to go this summer
3g racing
No more than 170hp with stock pipes
...if i hit 170 ill be very happy ....anything to gain to play with the size of the stinger ?they told me to put the aux ex port the bigger i can and sleeve the stinger to get them smaller some .....No more than 170hp with stock pipes
YAMMIEGOD3:16
i made 160 at c & h with my 2000 srx. stock pipes. stock carbs 700 cc. 2000 race box , lake race ported. 3:16x (yammie tony)
Tony, do you know the timing the race box provides? +2* +4*...?
thnx tony ill will go see jawsi made 160 at c & h with my 2000 srx. stock pipes. stock carbs 700 cc. 2000 race box , lake race ported. 3:16x (yammie tony)
What pipes are you going to run Mod ?
We have a full improver SRX 700 that original owner claims 190 + hp with custom Rosentrotter pipes
YAMMIEGOD3:16
i believe it is plus 4. 3:16x (yammie tony)
We have a full improver SRX 700 that the original owner claims 190 + hp with custom Rosentrotter 10200 pipes
stock pipe since to race in the 700 stock class u need to run the stock pipe ...maybe will change or try different stigner size or length on dyno if jaws think it will be a benefits on a 660' race
Since when are you allowed to run a ported motor in stock ?
YAMMIEGOD3:16
you guys must make your own rules. 3:16x (yammie tony)
Since when are you allowed to run a ported motor in stock ?[/yes we are but the complete sled need to remain stock ...or look like it
