dyno hp for a ported srx and case and 35mm carb
modsrx
canada,qc
anynone got a idea what a srx with a ported cylinder ported case ,,35mm carb , bump compression with c12 gaz could do about hp on a dyno ....i plan to go this summer
No more than 170hp with stock pipes
...if i hit 170 ill be very happy ....anything to gain to play with the size of the stinger ?they told me to put the aux ex port the bigger i can and sleeve the stinger to get them smaller some .....
What pipes are you going to run Mod ?
We have a full improver SRX 700 that original owner claims 190 + hp with custom Rosentrotter pipes
We have a full improver SRX 700 that the original owner claims 190 + hp with custom Rosentrotter 10200 pipes
stock pipe since to race in the 700 stock class u need to run the stock pipe ...maybe will change or try different stigner size or length on dyno if jaws think it will be a benefits on a 660' race
