Plug and Play LED Headlight
sledders
Melrose MN
This for XSR 2000 which has no battery, presume AC to head light. If so will the LED work without inserting a diode to smooth out the sign wave?
If you tap off the factory "back up alarm" wire then you don't need the rectifier. The back up alarm has a rectifier to give clean DC voltage.
